brightspark
- yarm stockton on tees
that is a timer fan that requires a permanent live and a switched one and neutral the feed up is just a switched one so someone has linked it to make it run
most are humidity and timer requiring 3 cables as u say you could get a switched live from the lightSoo question is can you get a new 3c +e wire down to the fan or up from it then you could use the existing wiring and a switch live from the light to save chasing down to the switch?
Humidity version looks like it can operate with just live and neutral!
Sy
not seen any drawings just for 2
Is it on the ceiling? Might well not be in zone.Fan is also in Zone 1, so i think a standard Manrose fan is not correct anyway?
Can't see any solution past pulling another cable sadly.
How high is the ceiling? If it's over 2.25m it is out of zone 1 and should be fine with the Ip rating of IPX5!
Rules be rules.Yep so out of zone 1
Not by much but it's definitely not in it!
Nicking a switched live out of a light would save a lot of faff. Do fans need an isolator switch?Fan is also in Zone 1, so i think a standard Manrose fan is not correct anyway?
yes and no .if its on the same floor as the distribution board and fitted with an mcb no that is the isolator for the circuit .. if on a diffrent floor yes it is needed an odd one but trueI'm sure i remember having to put one in on a property after an EICR flagged up there wasn't one.
