Glad you said that, thought I was going mad. All my sets have 15-16-18 and they all get used.
There is a company that makes a set of "tool box " spanners that have the ring and the open end oon each spanner being a different size so one set of spanners can undo a nut and bolt
Really pees me off, incomplete spanner sets....
If there's no 15mm or 18mm sods law you're going to need it.
Facom , (auto-corrects to bacon!), Normally do but......
Not this set, which I really like, no 15mm, doesn't exist, they don't make one either!
Common for me on French Japanese engines!
Twinset spanners i think theyre called
I've always known them as combination spanners.
This is a twin set
Thought a combination spanner was just a standard open end and ring the other end?
This is what i mean do you call this a combination set?
There had to be one!Even that set is missing the 29mm. Ask anyone who has ever worked on an Isuzu 3.0 diesel engine if they need the 29mm.
It's the same with Allen keys. Pretty much all the sets I have seen go .....5, 6, 7, 8, 10. No 9mm for some reason. Then go look at Jag brake calipers, yep, you need the 9mm allen key to change the pads. Single 9mm can be bought now more easily but I had to go to the Snap On man with jar of vaseline in hand. £22 for one 3/8 drive socket based Allen key.![]()
I’m the opposite - I seem to have loads of 15mm spanner’s and have never needed one, but they are somehow always on top of the pile when I’m lookingThe new cam chain tensioner bolt on my BMW bike has a 15mm head on it, and finding a spanner that size in my copious piles of spanners took longer than doing the actual tensioner swap. Plus, the bolt is in a really, really awkward place to get to.
