the make also has the same problems with a diverter valveNot if it's a Viessmann, but it's irrelevant dissipating the heat soak remains the same, how is it done @gaz1 ?
You might have said, but why don't you just turn off the valves at the rads that are in the way, drain and remove them and leave the rest of the system untouched. Then when ready drain the system, alter the pipes as needed for the replacements and refill - could be done fairly quickly and only a few hours downtime.
Your first post stated there is only 1 hx, combis have 2.I don't understand the point you're making?
The question wasn't how many hx are in the boiler, but how does the boiler deal with the heat soke of running a hot water tap.![]()
I haven't the energy to compete.Your first post stated there is only 1 hx, combis have 2.
You then went on to say Viessmann dont but they do.
A number of people including me have said what happens when the hot tap is turned off![]()
