Craig-SM
- Heckmondwike
I plan on removing the radiators in the kitchen and replacing with K2 ones which will be more compact. I will obviously need to drain the system down to remove the old ones but as I'm going to making adjusting the pipe work, repairing the walls and repainting whilst they are off am I OK to carry on using the hot water as it will most likely be spread over a week?
It's a Worcester Bosch 28CDI sealed system if it makes a difference.
screw that on, alternatively, a washer 1/2 nut and a 5 pence piece will blank it off safely until you're ready to do the pipe changes. Then you're olny dumping the water out once.
