The nose piece is 3mt they fit straight into the headstock there is also a nose thread protector.do the collets fit on in place of the chuck?
I dont have the drawbar but they are easily made.
There are some odd wheels also I'll try to see what they are.If there 16dp id be interested In Rehoming them.
Collecting odd ones up for boring or sleeving to fit my S&B
Pretty sure I'm 14.5Take care because as I said before Denford like to use 20pa gears and Boxford 14.5PA. It's not a rule but that's what's widely used.
Taper turning attachment covered in oil and grease.View attachment 183383 View attachment 183384 View attachment 183383 View attachment 183384 View attachment 183385
If you are looking to part with it I might be interested.
Yes that's right the Viceroy ones are usually painted red and the Boxford ones grey.Take care because as I said before Denford like to use 20pa gears and Boxford 14.5PA. It's not a rule but that's what's widely used.
I messaged the Ebay seller asking would it suit a MK1 metric Bantam but he said no but had a Screw and Nut for sale. Just sent a message again to see if he sells metric nuts only, heres hoping.
The nut will only be as good as the screw. If the nut is worn out with use the screw will be suspect.
Nevertheless some times the nut is better condition than the screw steel wears pretty quick when not lubricated, ive seen plastic nuts with less wear than the screw.The nut is bronze and the screw is steel.
