BrokenBiker
- Newport, South Wales
Reckon it's worth a shot to whip the DPF off my x type and blast it with the blow torch for a while, try and burn some of the crap out?
I've got the dreaded dpf full red light, flashing coil light, maf/differential pressure monitoring suggests the dpf is clogged with readings of 32+kPa differential pressure when maf is reading around 90-100g/s, realistically that pressure should be half what it's reading for a healthy dpf...
I've resigned myself to 200 quid for an aftermarket dpf but as ill be breaking the nuts/bolts loose before actually attempting it i wonder if it's worth trying to 'cook' the soot out of the current one?
Annoyingly the reason for the regens failing once again appears to be the egr is stuck, so thats got to come off for a clean as well, which bugs me as it's only 8 months old itself. I caught it early last time and got the egr swapped before the dpf was anywhere near full, not so lucky this time.
This all ties into me wanting a van as the jag has been dying a death for a while now, was hoping to stretch it out a few more months though and get through the summer before changing it
