JOEPRO
- UK
Really?? You've kept that quiet.
It's really a diesese at this point
I highly recommend it however. You should have at least 2 of each model also as it makes troubleshooting so much easier.
Unless it’s a common issue to that model and both suffer from it.it makes troubleshooting so much easier.
Only once you have found the cause, repaired tested and verified.If you were unfortunate enough to come across the same problem in 2 cars then at least the same principle applies.
Buy a part that fixes one then you know the same part twice will fix the other one![]()
According to the date stamp, I took this pictrure on the 3rd of Feb last year. I use mine all year round and as you say, all part of the fun.Left the house last night in the sunshine and not 10 minutes later it was battering down with rain. No doubt others on the road were wondering much about the same as yourself; why would you want to drive an old car, let alone in this! All part of the fun..
BTW, I suspect like yours, mine also has no heater!
If I had the money and the space I'd certainly have a fleet of interesting cars.It's really a diesese at this point
Another use for the forum funds, much better usage than all those exotic holidays.If I had the money and the space I'd certainly have a fleet of interesting cars.
The MGA I had mid 70’s had an MGB engine with a stage 2 Piper head, it made a great tow car, I used it for towing our trials car around & borrowed a caravan & took it to North Devon. It had oodles of grunt, pulled really well, but the car was an utter shed, fibreglass wings all round. Bought for £185 & sold for £300, I think it’s the only car I’ve ever made a profit on.It is rewarding when you get them running nicely. MGA has a 1950cc stage 2 engine and it was a pain to drive until I discovered 123 tune distributors. Spent a day doing a map and it's really easy to drive now.
20 years development to get to the point where you can just jump in and drive and not have to worry about anything. Makes a nice noise on throttle too.
Who needs a heater when you can put another jacket on!?According to the date stamp, I took this pictrure on the 3rd of Feb last year. I use mine all year round and as you say, all part of the fun.
Post office employee. Missing funds. Sound familiar ?Another use for the forum funds, much better usage than all those exotic holidays.![]()
What became of this one Mr Greeves ?I built a Marcos Mantula in the mid 80s using a new Rover V8 engine and gearbox, with an Offenhauser manifold and a 4 barrel carb. Would be a classic now. Wrong shocks on it in this pic, lowered with the correct ones after a visit to the factory.
I built one for a mate around the same time you built yours. He purchased a vented brake disc kit and ally front hubs from Marcos , the front hubs needed machining to fit the stub axles , the brake calipers needed washers to space them centrally over the discs, This, after talking to Marcos , was their solution rather than sorting things properly. The list of crap solutions went on and on ,Ran it for about three years but it wasn’t get much use so was sold to a car dealer friend, at a profit if you don’t count the time building it. Still on DVLA but not taxed since 2005. May have been re registered but one problem of the front end getting light at high speed may have led to its demise.
If I remember correctly, they used Triumph uprights and of course brake calipers machined to fit. On Triumphs, there's a brake disc shield trapped under the calipers - so every car that uses those uprights and calipers, but not the shields needs thin spacers to place the calipers correctly. You might confuse them as washers - but they are spacers of a specific thickness. My Caterham uses them with no problems, as does my trials car.I built one for a mate around the same time you built yours. He purchased a vented brake disc kit and ally front hubs from Marcos , the front hubs needed machining to fit the stub axles , the brake calipers needed washers to space them centrally over the discs, This, after talking to Marcos , was their solution rather than sorting things properly. The list of crap solutions went on and on ,
Correct, I used GT6 discs and calipers, better than the usual Herald.If I remember correctly, they used Triumph uprights and of course brake calipers machined to fit. On Triumphs, there's a brake disc shield trapped under the calipers - so every car that uses those uprights and calipers, but not the shields needs thin spacers to place the calipers correctly. You might confuse them as washers - but they are spacers of a specific thickness. My Caterham uses them with no problems, as does my trials car.
Same system on the Scimitar, but the shield is held captive under the bolt heads and being there or not wouldn't affect the centring of the calliper. Fitting Wilwood callipers was even more interesting and took some careful shimming as well as the pads shaving down a smidge.If I remember correctly, they used Triumph uprights and of course brake calipers machined to fit. On Triumphs, there's a brake disc shield trapped under the calipers - so every car that uses those uprights and calipers, but not the shields needs thin spacers to place the calipers correctly. You might confuse them as washers - but they are spacers of a specific thickness. My Caterham uses them with no problems, as does my trials car.
