Andrew Hart
New Member
- Chesterfield, UK
Any more thoughts from anybody before I bite the bullet and fit a manual unloading / dump valve?
As soon as I started reading this my thoughts were electrical, either the capacitor and or a winding issue.One of the windings may have deteriorated causing the start problem. Why I asked if the original cap was close to 60uf when measured.
What HP is the motor?
Could the capacitor be the wrong value from the start? (I know you changed it like for like, could it be faulty?)
Is there any situation where it will not start when you are sure there is no air in the unloader circuit?
Must say you have tried everything I would have thought of and I'm pretty stumped now.
Do tell us how you fair.
You learn a lot more from the tricky problems.
I usually check motors with a pat tester, insulation test to see if there are problems but not something everyone has access to. Had problems with one a while ago motor would run for about 10 seconds before rcb would trip. Motor had well under 1Mohm resistance but unlikely to find with a multimeter
dont think thats your problem though. leave the delivery pipe off the head and see if it still does it.
What grade oil did you use? I'm in the middle of refurbing another clarke and its developed similar after replacing the oil. manual states SAE40, but the WWW seems to advise SAE30 for clarke piston comps.
I am not sure of the rated motor power, there are no markings on it at all and I don’t have the manual for the exact model. It takes around 20 Amps after the initial starting current of 45-55 Amps, which is around 2.2KW or 3HP @ 110V. The original capacitor was 60uf 330v (measured 58uf), but I replaced it with a 60uf 440v item (no reason for the 440v except that’s all I could get quickly) and it made no difference.
First start of the day when it is cold and definitely no air in the unloader circuit it struggles to run. I have been researching this a lot and this can be a big issue in colder parts of the world, and a lot of countries fit “cold start valves” to their single phase AC compressors to unload them for the first few cycles until the motor is up to speed.
I thought the current draw was the problem until I remembered it is 110v.
Still I'd expect it to be drawing slightly less than that, if it's 3HP it's working hard and on the limit.
if I leave the delivery (discharge) pipe off the head it starts every time, hot or cold.
I used ISO 150 (SAE 40) mineral compressor oil when I did the oil change. The oil I dropped out was the original oil so I assume this spec too, and the compressor used to run fine. My original thoughts when I had this problem was corrosion in the bore as it had stood unused for 8-10 years until this year. When I stripped it down it was like new inside so I dismissed that theory.
Whats the voltage at the motor or switch when running? less than 110v will see a higher current draw
have you disassembled the check valve in the tank. its not sticking shut or partially shut is it?
duty is 7bar. you dont run it any higher do you? I'm assuming that the 16.5a is based on a service duty rather than max pressure?
Oil is too thick(not letting go of that one haha!!)
thats my tuppence.
As above it will require as a minimum 2.5mm extension cables ideally 4mm, from a transformer rated at least 5kva.
Volt drop on 110v is a big issue.
Had a customer with a hoist that kept coming back with an intermittent fault in the solenoid coil would not always hold. The thing was 100% when tested, in the workshop, I eventually went to test on-site top floor of a 5 story townhouse conversion. 10kva transformer at the site entrance, I counted 7 spider or splitter boxes before the box on the 5th floor. Measured roughly 45v offload, when the coil pulled in the best drop I measured was 36v phase to earth.
Has it been happy running on the transformer you have? Definitely check voltage off load and on load. Other than a winding fault as you seem to have covered everything else.
