A diamond metal cutting disc for an angle grinder?
Yeah, will go grab a pic.
WOW,strange,as the only one i see on MM is a 300mm disk diamond cut for metal that is
But as you've shown 115 amazing
to move it is simple a round scaffold bar and roll it for just one person
when cutting it rest it on 2 3x2s allow one side to fall down onto a piece of lathe
take your time cutting that 5mm sheet let the grinder do the work dont push it into the work and you should go through 2-3 discs if cutting up a 8x4 sheet
Table won't roll, not upright anyway; it will have I flipped it so the plate was on the ground, although too heavy for me to do that. I forget why it won't roll, something to do with the frame as that was my plan when I bought it, but we had to lift it, something to do with the frame that stopped us from being able to roll it.
Great, they are not cheap but 10+ euros are surely worth .I think I'll try and pickup one of those CEE/Schuko adapters; once fastened on it'll avoid me getting somewhere and finding out I left the adapter at home.
Very practical to use
You open it , plug the schuko in it, tighten the bolts,then close it ,put 4 screws and it's done.
It can't be removed unless you intentionally disassemble it .
Tomorrow I will make some photos of the one I have
They are produced by ROSI ,you have to search this brandI had a good look around earlier; but couldn't find one like that, think it's a great idea.
Yes is itUsed 'ROSI' in search this time and looks like I may have found it now; https://www.fershop.eu/adapters-ind...ndustrial-rosi-p-plug-schuko-3p-16a-ip44.html
That's the main vantageI'll certainly order one if I pickup a GYS machine. Really liked the idea of it being fixed in place, so it doesn't get left behind or lost.
