I reckon if those pulleys in post #41 and the coupler had been donw with a wet sandblast they would have come up a lot better especially the pulley.
) its 15mm so thats about right.If you're doing that a fair bit? you would be wise to go down the wet sandblasting route must cost a bomb in Citric acid and having to lift and haul it in and out a few times,couldn't be having that me.
No way will I use sand or media on an engine block as there are too many places for it to sit ready to ruin nice shiny bearing surfaces.
Take it you have used this ?
My thoughts to on the price. If it's for a known/popular name washer, that bumps the price up. Machine Mart prices are crazy as well.I'm just amazed at the prices some firms are selling the lances at,anywhere between £40 upto £120.
When you break the lance down from an attachment to the washer to the metal tube and the head is only made of plastic surround with brass fittings but the cleaning tip is anywhere between Stainless Steel to Tungsten,the thing is not worth some of the prices offered,you can make one up if you have the tools and a Lathe to make it.
A square block of aluminium or brass will do the head because the head has a hole drill the length of the block and another hole drilled towards that other hole at an angle.
How do they come up with these silly prices for a component that probably cost £12 in materials.
Some have used the ceramic from spark plugs as nozzles. Think it needs to be older type of plug to allow removal of the ceramic partIf anyone is interested in making their own lance? this was the way i was going to go before I came across the wickes lance which they seem to have not stocked it anymore?
The attachment to the washer gun was here down the right hand side halfway down page ie different brands and fitting for most major brands,not checked ebay recently.
http://www.flowjet.co.uk/shop/product/st73-foam-lance-with-1ltr-bottle.html
The nozzle head was going to be this in the link(bit of ingenuity on my part) its 15mm so thats about right.
Taking the bolt out that would be where the tube would fit onto with a threaded brass tube.
http://www.toolstation.com/shop/Plumbing/Compression/Compression Inline Y Filter 15mm/d20/sd2697/p52821
The lance would be any hollow 15mm rod with a 2mm or 3mm wall thickness brass would be better as the steel would rust unless stainless? one end would have to be thread for the attachment depending on if it is threaded? usually are.Other end will be compression fit onto nozzle head.
I'm trying to find the site I saw when putting this together at the time,the nozzle head bit thats needed for head but I was prepared to make a few out of stainless steel on my Lathe looks like a bullet with a fine 1.5mm hole going through it.
15mm tubing also needed for sand to nozzlehead.
I costed it up at the time and came somewhere to about £10/£11 with all components excluding the nozzle bit helluva saving for what the lance is.
This what gave me the idea of the nozzle head...
http://valleyind.com/wp-content/uploads/VI-Catalog-211A-11-10-11_Page_73_Image_0007.jpg
Last time I tried that could not get the inner conductor out and it was to hard to drill (was a plug from a fiesta) What plug would come apart like this?Brilliant,the use of a spark plug,no need to seperate the ceramic part,just remover the inner conducter and you make a thread adaptor to accept the sparky thread at the nozzle.
