There are basically two forms they come in. The complete-as-a-unit ones should not be installed inside a habitable building. Only the kits, where the exhaust is entirely isolated from the occupied side, are deemed as safe.
Chinese measurements V real world ones?AFAIK, they are all the same output, despite what they claim.
As a Chinese supplier told me:Chinese measurements V real world ones?
@JOEPRO has one fitted in his workshop.
Its a calory brand self contained type piped out through the wall. Great job maybe struggles slightly heating a masonry double garage with no insulation. Hence I have a second one to install now to boost it on really cold winter days.Great job maybe struggles slightly heating a masonry double garage with no insulation.
burdekins is half wall half fully insulated fut the roof is well insulatedYes I think it was on the day you were hereIts a calory brand self contained type piped out through the wall. Great job maybe struggles slightly heating a masonry double garage with no insulation. Hence I have a second one to install now to boost it on really cold winter days.
Ditto, I got mine from a coatings lab that was closing down and it's comically oversized for the space really.I have both. My dehumidifier is a desiccant type. It uses more lecky than a compressor type, so adds enough heat to my very well insulated workshop, to avoid condensation, most of the time.
I set the humidistat to kick in when the temperature is lower than 13°C and RH reaches 80%, or the temperature is greater than 13°C and RH reaches 90%, in both cases switching off when RH is down to 50%.It is cheaper to run the dehumidifier on a cheap tariff than use oil. A couple hours per night (about 3/4 of a kWh) is sufficient to reduce the humidity and raise the temperature sufficiently to avoid rusting.
That costs around 45p/week at the present time. I only heat for a short time with the diesel heater before and after I enter to work in there. After that the heater is turned to minimum or turned off - but I’m not in there all day long!
I've got a very old but good Webasto Airtop 2kw in my camper, but have considered one like that for my shed.I've just bought one of these, I was having a firtle last night (with the heater!) and wasn't impressed with the way that the exhaust is supposed to attach without leaking. Would it be best to use exhaust goo and a BFO clip (jubilee or other), or is there a better way?
Cheers
