If you don't have one to compare to don't assume the diaphragm is ok. They should be as soft as tissue paper almost. If there is any stiffness it will affect it. I've done a few of mine recently, some of them were a dog to start but were fine once running. Carb kits transformed them.
A top tip if you aren't going to be using it much then buy premix like Stihl Motomix/Aspen or if mixing your own use Esso Supreme 99, it has no ethanol in it. The Esso website confirms this unless you live in a certain areas. The amusing thing is the pumps are still marked E5 because they are required to do that by law. It's the ethanol that gooses these things if not used regularly
If you look on one of these sites and look at the carb kit pictures you will most likely find a kit even if it doesn't specify the exact name. Diaphragms can be a bit funny as there will be subtle differences in hole locations. Sometimes it doesn't matter as the hole is covered.
https://www.gardenhirespares.co.uk/
https://www.lsengineers.co.uk/
As @Seadog says the tubing can be a nightmare, many sizes and often you find different outers with the same inners, this can be an issue they need to fit tightly in a tank grommet.
I wouldn't get too carried away with it, you can buy a bottom end Stihl or Husqvarna for £130-145
