A few ideas...2.7.11
Covert recording of consultations If the HP notices a claimant is covertly recording their consultation, the restrictions relating to the recording of consultations should be
explained to the claimant. If the HP is content to be recorded, the claimant is content to sign the agreement form and the claimant’s equipment meets the specified requirements, the consultation can
continue. If this is not the case the claimant should be asked to stop recording. If the claimant refuses, the consultation should be terminated and the case should be returned to DWP using the return
assessment function with reason failure to participate. The CM will consider whether the claimant has good reason for failing to participate in the consultation. If the only reason for failure to
participate is the claimant refused to stop recording their consultation, it is likely the CM will make a negative determination
1. Possible loophole, Could you ring someone up and let them listen in on your interview ? you could say it's your "lawyer", no recording involved. If that would be allowed I'd have the "lawyer" live stream the interview on the internet, again no recording involved but that way you could have loads of witnesses listening in all willing to back you up as to what was said.
2. Are you allowed to take in a 3rd person who could note down the interview in shorthand, they could write on carbon paper so there would be multiple copies to go around at the end of the interview. You could then give the interviewer a shorthand copy (let them struggle to read it
) and you get both the short and the long version produced after the interview.
