Y yarpap Member Messages 166 Mar 25, 2010 #22 yep everywhere, thanks for the pointers i shall see what happens in the morning Dave
Y yarpap Member Messages 166 Mar 26, 2010 #23 strange but true, ran perfect this morning and again on way home,thanks for the pointers everyone Dave
B Bigjoe Moved to the country! Messages 1,875 Location Guisborough,N Yorks Mar 26, 2010 #24 MAF (mass air flow meter) sits between the air filter housing and engine,looks like a plastic or matal tube with pipes attatched normally. If it does it again,have a look at the wiring connector on the MAF as it may be loose or dirty/corroded. also check all pipes/hoses in the area.
Y yarpap Member Messages 166 Mar 26, 2010 #25 cheers Bigjoe its due a service but its something i loath as an Engineer having to take it in to a dealer, to many electronic gizmo's
S stinkbridgenine Member Messages 93 Mar 26, 2010 #26 i have a EOBD fault code reader,it`s only basic though but you`re welcome to plug it in if you want,it may point you in the right direction. i`m in oldham also.
Y yarpap Member Messages 166 Mar 26, 2010 #27 thanks for the kind offer, will see how it goes and if it plays up i will take you up on it Dave
R rhubarb7 Member Messages 298 Location ? Mar 26, 2010 #28 Does the Engine Management Light, light up when you turn the ignition on? If like doesn't stay on, then there won't be any fault codes recorded/stored.. If the MAF(Mass air flow)sensor is starting to fail, it won't put the eml on If the van plays about again, unplug the maf plug, and drive it, if near normal performance comes back, then its faulty..
Y yarpap Member Messages 166 Mar 26, 2010 #29 emg light comes on when ignition is switched on, goes out as soon as car starts, no loss of power at all today, so hope alls ok
B Bigjoe Moved to the country! Messages 1,875 Location Guisborough,N Yorks Mar 26, 2010 #30 Good chance its the MAF then, try Rhubarbs trick if it happens again.
