On the thinnest stuff you should be on 0.6mm wire & on the lowest power setting, wire speed low. You generally only get wire burn back to the tip if the wire speed is too low or if the torch lining is blocked. Again, with it being a new machine, the torch lining should be fine unless your wire has started to go rusty? Rusty wire could explain everything.
weldequip
weldequip
