Diesel welders come in for a really hard time on site, people push them around with JCB buckets, fill the tanks with water and dirty fuel, run them out of oil and shot-blast all over them to name just a few of the commonly occurring perils lol. It's hardly surprising they can develop reliability issues fairly early on in life.
Interesting Jim, We have a couple with no bother and most steel snagging gangs have a big Mosa bolted inside their van. Recently gone cr@p?
Do you do much with Lorch then?![]()
Its bad the way hire stuff gets treated generally, people wouldn't treat it like that if it was their own.
A welder generator is a relatively simple beast but they can be aggro to work on. Some more than others. Faults are normally on the electrical side but not exclusively, there are a number of circuits, one for controlling the welding output via thyristors, a system to sense when the machine comes under load for the auto idle, chokes, capacitor banks, lots of wiring subject to alternating cold, heat, damp, oil, diret, fuel and vibration. Worst thing is the sheer compactness of most generators. It can make them very labour intensive to work on as you have to remove several things to get at components to test them. On a diesel MOSA or Genset it's a heavy one piece hood you can't take off yourself requiring two people to fit. They often bury chokes, capacitors and rectifiers in the base of the set where all the greasy dirt and any loose but/bolts will end up all trying to short circuit something . They often have a bulkhead where all the generator output/input wires pass through that can chafe and short out wires. And it's a complete strip down if a fault develops on rotor or stator. Frankly I'd rather pay extra for a really well designed set where all the cables are run in split conduit and cable tied, boards are potted in resin to keep nasties like moisture and vibration from damaging stuff, casings are thick so they don't rust out easily with proper paint not flaky powdercoat and that they are laid out with service/maintenance in mind rather than an afterthought. Add a noisy vibrating and hot air cooled diesel into the mix and you have a winning combo.
When the 2 stroke motor packs up on it, you can stick any old prime mover on there. For a big set I'd say lincoln or miller (there is a big blue 400 on ebay for £1500 with a deutz inside)
