Had a look inside torch an looks ok so opened it up,found the blue air pipe kinked slightly but not totally otherwise i'm lost,here's a few pics if they help,cheers Dan
does it have a working pressure gauge...iff not then find out its working pressure and get a gauge somehow linked from the internal pump or from the blue pipe at the torch head endBit daft but how do i do that?
if the air pipe is kinked and causing an air restriction it could be your problem so worth trying a fix for that firstI might aswell cut all wires just behind damage an re-fix from fresh
it may also be worth removing the head of the compressor and check the reed valves are still in one piece and that they are clean if not they will reduce the amount of are producedCut the air pipe at kink then re-attached,now it cuts anything,thanks people,fingers crossed although new tip isn't gunna last that long by looks of it
