angellonewolf
- bristol england
What brazing rods for this and flux ?
If you go anywhere near it with a flame, you need to be absolutely sure, certain, positive there is no trace of petrol or vapour left in the tin or it will go bang.
its been cleaned a few times and ive been near it with a blow lamp already i did try plumbing solder but wout not take {i was not suprised but hay hoI soldered a motorbike petrol tank, with rust holes, using a blowlamp after carefully flushing through several times
its not the handle that need to be attached its a hole after its been hit i would saytake the handle completely off scrupulously clean it. flux and tin it the same with the can lid . dab some flux on and sit the handle on top heat with the blowtorch till the solder melts and feed a bit more solder in job done
just scrupulously clean it then tin it either using a large soldering iron or can be done with a blowlamp. it should fill without a patch if your handy with the torchits not the handle that need to be attached its a hole after its been hit i would say
