Barry Hoys
- Manchester UK
Ah cool, sounds good, cheers matehttps://www.selfadhesive.co.uk/scot...xI6OPUSLVSetnrxSJ-aswmd-in820HIsaAoXnEALw_wcB
15 quid. Dont bother about the mixing tips, I just dispense into a plastic pint glass and mix with a lollipop stick. I would buy the pusher as well if you are using it much (or the gun if you are using it regularly) but if it's a one-off job push it out manually with a socket the right size on an extension bar.
The ratios need to be correct so either measure the amount dispensed from one side before pushing the other or mix up the whole tube in one go
