Brass and Steel
  1. Barry Hoys Member
    32
    Manchester UK
    If I tried to weld brass onto mild steel with a normal Mig setup, would it work? The welds will be hidden so don't need to look great. What would be the normal approach to fixing 2 different types of metal together?
    Failing that can anyone recommend a glue that will form a good bond between brass and steel?
    Cheers
  2. johnser
    johnser Member
    1,864
    North Cornwall
    I accidentally tried to weld a brass tube to steel once (it was chromed). It made a mess. Some of the mess intermingled and held the two bits together somewhat but I thing friction was doing the majority of the holding as opposed to any kind of fusion.
    Brazing would work.
    Barry Hoys likes this.
  3. hotponyshoes Member
    1,855
    Somerset. Uk
    Plenty of glues that will do the job, what's the application?
  4. Barry Hoys Member
    32
    Manchester UK
    It's to fix a brass hinge onto a steel frame. Glue would prob work as it's not taking any significant weight.
  5. ronan
    ronan Forum Supporter
    9,414
    dublin
    Solder it , even soft lead based solder should be pretty strong.
    Barry Hoys and Maker like this.
  6. Munkul Member
    1,367
    Cumbria, UK
    steel mig will not work. It needs to be brazed, soldered or glued.
  7. hotponyshoes Member
    1,855
    Somerset. Uk
    3m scotch weld metal adhesive
  8. bourbon Member
    628
    Lichfield UK
    Plug weld through the screw holes?
  9. grim_d
    grim_d Forum Supporter
    2,135
    Scotland - Ayrshire
    Scotch welds are something else. The rest of the adhesives industry has a lot of catching up to do.
    mike os and Barry Hoys like this.
  10. Maker
    Maker nEw mEmBeR
    6,996
    Don't ask questions
    Bolt it? :dontknow:
    eLuSiVeMiTe and Barry Hoys like this.
  11. Barry Hoys Member
    32
    Manchester UK
    Cheers everyone, prob try that scotch weld
  12. eLuSiVeMiTe
    eLuSiVeMiTe Forum Supporter
    10,457
    Bedfordshire England
    If it's light load could probably drill and tap for countersunk bolts.
    Or use a weld on hinge and ditch the brass.
  13. hotponyshoes Member
    1,855
    Somerset. Uk
    If you follow the instructions perfectly for the 3m stuff you will rip metal before the bond gives up.
    slim_boy_fat and Barry Hoys like this.
  14. Pigeon_Droppings2 Member
    2,222
    london
    Would mig braze wire work (CuSi wire...its bloomin expensive though)?
    I've used mig braze to join mild/stainless but never tried it on brass!
  15. Richard.
    Richard. Member
    18,311
    Cambridgeshire
    A tig or gas braze would provide the nicest joint.
    Here’s an example of a bank stick I made for my fishing.
    The brass threaded bush I made is tig brazed to the steel rod. For a tidy job I machined the brazed joint into a step to make it look jointless but I can assure you it’s brazed and it’s solid.
  16. hotponyshoes Member
    1,855
    Somerset. Uk
    I have got a roll of cusi .8 mig wire I could chop a bit off if you want to try grazing it?
  17. 500e
    500e Always buy fire insurance a flood is hard to start
    4,162
    SWest UK
    Any "3M" or "Lord" product is going to be Expensive unless you can find a user with a bit left or you have an ongoing use,most of those types of adhesives have storage life.some as short as 6 months once open
    @richard said "A tig or gas braze would provide the nicest joint".
  18. Barry Hoys Member
    32
    Manchester UK
    I'll give the scotch weld a try but thanks anyway
  19. 500e
    4,162
    SWest UK
  20. hotponyshoes Member
    1,855
    Somerset. Uk
    https://www.selfadhesive.co.uk/scot...xI6OPUSLVSetnrxSJ-aswmd-in820HIsaAoXnEALw_wcB
    15 quid. Dont bother about the mixing tips, I just dispense into a plastic pint glass and mix with a lollipop stick. I would buy the pusher as well if you are using it much (or the gun if you are using it regularly) but if it's a one-off job push it out manually with a socket the right size on an extension bar.
    The ratios need to be correct so either measure the amount dispensed from one side before pushing the other or mix up the whole tube in one go
    slim_boy_fat likes this.
Advertisements
