I'm trying to find out - I just so wish you could remember how you solved the problemI'm sure i had this problem once before, is it to do with the setting depth ?
Thanks for taking the trouble to post pics - my stuff is identical to this - you didn't photo the small container of red grease
Your observation is plausible - I haven't tried "more grease" - will try tomorrow when I have calmed down.It doesn't look like the tubing, or the flare itself is turning. Only that the punch, as it's being screwed in, is imparting a turning moment onto the flare, as it's forming, and creating the stresses that might possibly cause it to collapse. Relieving those stresses with an extreme pressure grease, might be enough to stop it.
Will photo tomorrow and post.A picture of the end of the die would also be useful to see if it that is malformed.
You should still be able to get a reasonable flare with that tool almost every time - the issue I had with them was the threads didn't last and stripped out.
I also used a cheap clamp type tool like the one above for yonks and it was very hit and miss to get a good flare. The sykes type makes a perfect flare effortlessly every time.
I agree - something is not right but I just cannot sort out what.no one local loan you the flare tool or pop round and use it?
id offer to let you use mine but im miles away , does sound like your flare tool has a defect
This pix is causing me concern.OK - please see attached photo's, many of which should answer points previously made. I have now literally tried everything, using oil as opposed to grease as lubricant and even annealing the last 5mm of the end of the brake pipe - all to no avail. I have even tried using brake pipe from differing suppliers.
I simply cannot reliably reproduce a good flare - I make 1 good one - then 5 bad - the last photo shows some of the results, out of 25 attempts, 18 of them I would classify as failures and only 7 are good.
I pretty much give in with this and am ready to dig a big hole and bury the whole project - I have been at this for some days and for something so straight forward it is seriously getting me down
A friend of mine uses the same system and I am going to borrow his to see if the fault lies within the die and the punch itself.
i debur mine with a tool similar to this
Agreed. It looks like the ID needs a touch more deburring.This pix is causing me concern.
Is this just after cutting with the wheel ?
Looks like material is pushed down into the ID.
which tubing cutters do.
Can you take a small countersink tool, and run it on the end there to clean out the ID ?
I'll second that. An EP lubricant might help.It doesn't look like the tubing, or the flare itself is turning. Only that the punch, as it's being screwed in, is imparting a turning moment onto the flare, as it's forming, and creating the stresses that might possibly cause it to collapse. Relieving those stresses with an extreme pressure grease, might be enough to stop it.
Yes !Agreed. It looks like the ID needs a touch more deburring.
The quality of the interface surface of the screw-in punch could also be a factor. For example, if it isn't smooth enough, there might be more twisting force applied to the tubing.
Please see attached photo of the die. I can see no obvious fault hereWill photo tomorrow and post.
Yes - the tool is regarded very highly with great success rates on many forums of idiots like me rebuilding classic cars.
I'm sure the sykes type are wonderful - but I am retired - my money tree is dead and I am rebuilding this car is a hobby.....
Thanks jsf55 - I know and understand - they are simplicity in themselves to use and no body yet has experienced the same issue as I am having - I believe the issue has to be in the tool.I tried mine yesterday afternoon ... but i went out last nighthope it helps ? i only dabbed a bit of Rocol tapping compound on it as it was too hand !
View attachment 454865View attachment 454866
View attachment 454867View attachment 454868View attachment 454869
