The drill is following the bore of the centre tube, so actually easier than you might expect.
without spending £££ on a 26.2mm reamer?
Go the other way. Make a drift and bang it all the way down
Edit. Missed that the inner tube still has some meat left at the top
So the hole needs to be 26.2 but is currently 25mm ID down to 7" deep, and the 25mm bore is guiding the bit?
£34!!!
If i have to, I suppose I'll have to.![]()
Then sell it on here ,perhaps get half your money back!£34!!!
Really what you want is something with a weld on shank. The. You could make a long spindle.
you could make a set of bearings to align the whole lot in the tube
I can make up a drill extension tomorrow if that helps. Is it 13mm drill chuck on the other end?
As brad said could you not tig a few dabs inside and then pull the remaining out with the bottom bracket in a vice via a dead crank arm?
If you have an old steel stem that would fit then you could cut a set of teeth at the end then a hole through the other end and insert a tommy bar and hand ream it out as it's ally.
I bought a frame off someone who had am interesting method of removing seat posts. He had made a pilot for an annular cutter and he bored the post out with it. I bought
a steel frame off him, with a seat post stuck in it, I didn't take him up on his offer to remove the post as I am quite a dab hand with the caustic.
To rem an ali post out of a mount vision frame, I chopped
the post off level with the top of the frame and made something like 8 slits
the full length of the post with a cengar saw. The slits were almost through
the post at the top, the post collapsed in on itself quite easily and there was not
a mark on the tube .
If I hadn't had my Cengarette I Would have used a jigsaw.
Took me about 15 minutes to make the slits in the seatpost, the Tompson Elite seatpost.
