jimcroisdale
Hiya all,
I'm making a table out of wide/flat stainless box section. Not sure of the exact size yet, but i think it's somewhere in the region of 100mm x 15mm, probably with a 2mm wall.
I'll make two mitred square frames out of this stuff which will then support the wooden top. Thing is, I want the tabletop to be suspended under the top of the steel frames.
I don't want to be able to see the fixings from the top of the table, so to bolt the wood to the steel from the underneath of the frame I'll need a way of single sided fixing.
The wood will need to sit flush to the steel. I might even rebate the wood so the steel and wood are flush on the work surface.
Any ideas? Drill and tap holes in the steel? Rivet nuts?
Kind regards,
Jimbob
Kind regards,
Jimbob
