It's the rocking arm that takes the load of the whole upper saw Inc motor.What kind of forces does it need to resist? If compression only then braze. Probably ok to braze if its a rocker with force parallel to the plane of the rib. Welding will make it brittle so if there is any bending, it will snap.
Again, received wisdom tells me only about 50% of typical cast irons can be welded at all!
You could try TIG brazing I guess but pre heat and silicon brass oxyacetylene brazing is the way to go, with a long cool down.
S.
It's got a bend in it sideways. ...Make a new one from steel plate.
especially as a new on is only 17 quid Inc vat. apparently. I bet I get stung for heavy carriage but as long as I know I cN get one I am happy to have a play...Weld it. Can't get any worse can it.
nope....lolFor £17+ carriage it's hardly worth the time to clean paint off, edge prep, pre heat, weld, slowly cool, grind back, re-paint. Is it.
