So the torch Snowy is using is a pencil shaped one and not a Binzel so considerably smaller that the WP 26 I have..... And the reduced size/weight makes things easier because the torch is easier to handle? I suppose as far as Binzel are concerned it cuts down on the number of mouldings they need if they use one for all.I see.So the torch Snowy is using is a pencil shaped one and not a Binzel so considerably smaller that the WP 26 I have..... And the reduced size/weight makes things easier because the torch is easier to handle? I suppose as far as Binzel are concerned it cuts down on the number of mouldings they need if they use one for all.
Its not necceserilly easier, its just personal preference, it would certainly be easier on very fine work at low amps, but for everyday run of the mill stuff I would just say its whatever type of torch your used to using and seen as your not accustomed to any particular type just yet, you may not find any benefit.
Perhaps I'll try clean and dirty to see the difference.
