https://www.mig-welding.co.uk/forum/threads/castotig-3002-no-slope-time.95755/castotig 3002 probably does its just me still learning theres a lot going on ill read the manual again
They started a trend with that machine and carried it right through the magicwave range and that is putting all the stuff in background menus.How did you find them when you were using them
Use these and you’ll likely never need to bother changing it again.Thanks ill get in there and have a look you have a great memory I read the manual over and over still find something new each time I read it would factory settings be a good place to start or do you have any suggestions for frequency etc
I dont know if it's the proper way to deal with ot but I find that you can lift off with je pedal at the end of the weld but still keep the arc going, then let it cool a bit and you can see the crater form, then give it a quick dab on the pedal with a bit more power and put another dap of filler into the crater to fill that in.
Off the pedal to break the arc and hold the torch in he same spot so the end of the weld cools under the post flow gas.
If you have enough post flow for the weld to solidify while the gas is still flowing it's easy to press again if you need to restart the arc and add a bit more filler to loose the crater completely.
ACF 90
Neg- rec
Pos- sin.
Best p3 settings I ever found on it personally.
