madkayaker
Pro sparkey Pro Welder
If you piped your self up to pure oxygen you would die as you would be unable to dispels carbon dioxide.
i know of a guy who tried the old, hse pipe on the exhaust and into the window of the car trick, but it didnt work due him owning a diesel.
he ended up in hospital for a few days coughing his lungs up but it didnt kill him
Unless you're stuck in the middle of a lot of it!![]()
Worse thing I've come across was Amine? gas, used as a catalyst to harden sand cores!
I work on several co2 dump systems at work and always leave all the doors open
It's supposed to painless because the feeling of suffocation isn't due to a lack of oxygen but from the build up of CO2.It has been used in a number of fairly peaceful (?) suicides. But that involved deliberately piping it into the lungs; it displaces air quickly enough then...
Pure oxygen can be toxic but i don't think it works like thatIf you piped your self up to pure oxygen you would die as you would be unable to dispels carbon dioxide.
How bad is it to weld with argon in a single garage (door open) without a gas mask?
if i should use a mask any suggestions on type etc?
Many thanks.
I did once work at a place that reproduced drawings on a massive Dyeline copier that ran using Ammonia
One of my jobs as an apprentice in the drawing office was to run prints off one of those.
You are fine to weld in an open garage, argon is not bad for you in low concentrations in a garage with the door open it will be negligible and you should wear a mask more for particle protection. I can't believe this thread has gone on for 6 pages and gone so far off topic without being closed.![]()
Or if you knock the valve off.Me to; although argon can be dangerous if you drop a cylinder on yer foot.
Paul G
