Argon is an inert gas, so isn't harmful in itself. However, it is an asphyxiant, which means it will, in sufficient concentration, displace the oxygen in the air, which will kill you. All you have to do is ensure that it can't concentrate. Habing the garage door open would be fine, as well as making sure your cylinder doesn't leak.
There is no need to worry about the gas.
If that was true we would all die.There some truth in these posts, youll be fine welding with it, but yes it does displace air.
Argon is a heavier than air gas, which means when it gets into your lungs, it sits at the bottom of your lungs and isnt exhaled. The more argon you breath in, the more your lungs fill with it, until there isnt any room left in your lungs for the air that they need.
So there is truth in the old wives tales of holding welders up by there feet to get the argon out of their lungs if they have breathed it in. However best way is just not to breath it in in the first place. But it is inert and wont poison you, just your body isnt tooo keen on having it in your lungs.
Steve
You feed any gas other than air, argon, nitrogen, CO2 whatever into a enclosed space and it will replace all the air.
It had nothing to do with the weight of the gas, more the risks of working in an enclosed space. With no ventilation, they will asphyxiate from lack of air and too much CO2 with no need for another gas.
The CO2 that is about 8% of what is in the air we breathe out is heavier than argon. As our bodies release CO2, we would all asphyxiate if that was true.I think the operative word here is diffused in air. Argon is heavier than air and if you breath it in, it will sink to the bottom of your lungs and fill your lungs.
Helium is different it is 1/8th the weight of the major air components.Ok, then what happens if its helium? You cant breath that. But that wouldnt stay in an enclosed space that was open to the top. Argon would, and yes it has evertything to do with the gas being heavier than air.
