The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
Back in 1989 in London a lot of the Black cabs did that, 6am after a night out was not all fun.
If you either use, or process, WVO for fuel use, you need to be careful with regards to HMRC.
If the total volume of WVO falls below a set value, you don't pay duty, likewise, if you process, or de-esterify, the oil, as long as you stay below a threshold you again, don't pay duty.
Remember, WVO or VO, is sold as a foodstuff and isn't subject to VAT, fuel is...
I dont know who is out there to police the use of Bio, we get HMRC in the yard dipping my trucks and they test for two things. One is kero or a dilution of and the other is red or rebated fuel. A percentage of each is allowable because of the cross contamination in the delivery tankers. No test for veg oil so they would probably have to be watching you.
Bob
not if it is let down with petrol
Either petrol or diesel, the density won't match pure road use petrol or diesel, they can measure density to within 0.001 with a manual hydrometer.
They can also do mobile calorimeter burn tests, each type of fuel sold has a specific range.
Also, by using a refractometer they can analyze the light passing through a prism, any differences from pre determined values and the fuel is sampled and sent for further verification and siezed...
I understand what you are saying but putting bio in your fuel is not illegal so who is out there to police the quantities folk are using? HMRC road fuel units only test for dye and a chemical thats in kero , I dont think they do anything else with the samples.
Bob
like i said it is perfectly legal to use up to 10000l tax free
less that i thought!
tesco tried to kick off a couple of times when I used to buy 1000 ltrs of diesel for my storage tank for the recovery trucks coz they were selling it 10 p cheaper than the oil companies plus you got a groceries discount, it meant we could fill up at all hours of day night holidays etc. And get my weekly shop free !
they tried to say the 205 ltr contains were not approved but they were and had the correct stamp on them.
You are required to declare anything over 2500 litres in a 12 month period...
Remember, with HMRC, the word "suspicion" is a very grey and dangerous area, if they "suspect" you of anything, they can enter, sieze, and remove what they class as evidence, until you can prove otherwise...
Rule of thumb here, document "everything"...
Re: ethanol content...
All "standard" fuels currently supplied should be/are either E5 or E10, the only exception to date has been Shell, who's premium, or "nitro" as labelled, unleaded is a non-ethanol containing fuel.
There have been many posts about this on the "piston heads" forum, as, ethanol in any proportion is no good for two strokes, garden machinery included...
You can buy stabilisers, produced by Oregon, or de-oxidisers, to inhibit, or remove the ethanol, but they aren't great. They work best with "dry" fuel, as by its nature, ethanol is hygroscopic and adsorbs moisture...
For domestic use this is limited to 2500 litres per annum and your year begins when you produce your first batch and runs for a full 365/6 days. For domestic use you need to keep all your paperwork and you can buy one machine and anyone can use it to produce transesterificated diesel from the one machine for any number of private vehicles and records need to be kept for each vehicle.
For commercial use you can only have one machine for each vehicle, if you have 10 company vehicles which run on bio you must have 10 machines; you are allowed the same 2500 L per annum, per vehicle, and after you use that you pay a reduced rate of duty for a certain amount which rises on a scale, basically the more you use the more you pay in duty.
Mee, with all due respect please read the article to which I posted a link to relating to this again, the 2500 litre limit before declarations are required is for either produced "transesterified" bio diesel, or, bio diesel substitute, or total volume of both used.
Legally, you can buy as many machines to produce transesterified bio diesel as you want, and run them as often as you want, without declaration, so long as your total produced and used volume of both de-esterified bio diesel and bio diesel substitute doesn't exceed 2500 litres per annum.
You cannot allow someone else to use equipment solely owned by yourself, in doing so any volume produced by them would form part of your total production for that year, irrespective of what paperwork states.
Furthermore, the same applies to commercial aspects.
In either case, there are no restrictions on the number of machines you can purchase, own or use, except what you premises size and your wallet allow.
Homemade bio diesel, as per recipes from the internet using methanol and caustic are nonsense and fairy tails. All you will effectively produce is soap, nothing more. Because you won't economically produce anhydrous conditions effectively without significant expense, were talking tens of thousands of £'s here for specialist distillation and processing equipment.
To produce bio diesel by transesterification correctly you need to use sodium dissolved in anhydrous methanol to produce sodium methoxide, a very powerful organic base, with a remaining amount of anhydrous methanol as the majority solvent/liquor.
"E" values for fuels were a maximum value originally, not nominal, please link to where this has changed.
