"The grid" ? Which grid is this then? If the OP can build it without the Authorities getting involved all power to him, but letsnot confuse water rights with the electricity grid here, different hoops to jump through, I would suggest the electric ones are the easier, and that's the only "grid" as far as I know..The system Farside suggests is, I assume, completely isolated from the grid so no danger to upstream lines people.
This would be dodgy at best, dangerous in other words...
The point being, if the grid fails, your generator has to disconnect - for safety reasons (if the grid failure is a local short you will be directly "across it", if it's remote and someone ends up working on it they could be killed. If there is a G59 type of relay it should disconnect the system.
Oddly, the simple asynchronous generator takes care of itself, in that in an open circuit fault the current goes to zero, thereby generation collapses. Adding capacitors (ie making 3 phase motors work on single phase) can override this, maintaining the current - so you really, legally need a G59/99 relay, if its mains connected.
Yes, I think the grid you mention is the electrical grid?"The grid" ? Which grid is this then? If the OP can build it without the Authorities getting involved all power to him, but letsnot confuse water rights with the electricity grid here, different hoops to jump through, I would suggest the electric ones are the easier, and that's the only "grid" as far as I know..
