Pete.
- Kent, UK
I'd search YouTube for back up proof, but, it's YouTube.
Yeah it's amazing what you can find with a pile of river rocks and a pot of gold paint...
Yes, I believe that's how it's done.... But...
All said, I'm not knocking you or @brightspark , but...
As I said to the 19 year old trainee today, have you seen the Star Wars films ? Use the 'force'.
I have done this, but the pipes were metal.have you tried the bent welding rods or anyone that does itworks for me
There is so much heresay evidence it works...A guy I worked with on BT used devining on surveys to find ducts & cables, he was really good at it, he would find things that we couldn’t find with a cat & jenny. If you watched him, it looked like he walked into a brick wall, I was never quite sure if it was the rods that moved & affected him, or he moved & it affected the rods. I tried to do it many occasions but could get no reaction at all, I wasn’t receptive to it.
Use the Force Luke.oh ye ludites, water devining has been going on for years, if it didnt work people wouldnt do it
i have traced plastic and concrete water pipes across fields and found an underground stream, all you need is a little faith Moriarty![]()
Have you ever triedThere is so much heresay evidence it works...
But how..?
I'm not doubting anyone, but I'm just a natural sceptic.
You can also swing a weight on a string, and ask the universe questions...
Use the Force Luke.
Try with the blast shield down...
Yep, water divining, to no avail.Have you ever tried
As far as I know science says there is no basis for it, but I can assure you, if you are sensitive to it, it works. tried to get the guy I worked with to do a bit of investigation, looking at ley lines & such, but all I got was “not interested”There is so much heresay evidence it works...
But how..?
Use the Force Luke.
Ooh Ley Lines.As far as I know science says there is no basis for it, but I can assure you, if you are sensitive to it, it works. tried to get the guy I worked with to do a bit of investigation, looking at ley lines & such, but all I got was “not interested”
Now you're talkingI'll go fetch the bong.
Now you're talking
Remember bumble bees aren't supposed to be able to fly .It's such an established 'art'.
I'd like to see a scientific evaluation of it real effectiveness.
But I'm a sceptic at heart.
I rest my case and will be quiet in the corner. (Possibly).Remember bumble bees aren't supposed to be able to fly .
In 1997 I found the incoming water supply to my old gate keepers house using a pair of L shaped 2.5 mm brazing rods ,. The water board couldn't find it , it was a good four feet below the road surface & nowhere you'd have thought of it being . Seems it was a new unsheathed copper pipe domestic supply put in , in 1961 ....tapped off an 1864 ..... 4 inch cast iron mains with the stopcock feet inside my property away from the main . I put in a standard 300 mm inspection tube & cast concrete cover over the stop once I'd gently eased it open & closed a dozen or more times .
