I need to locate two branches of buried 25 mm MDPE blue water pipe. One crosses a ditch, one crosses a small stream, both of which I will be clearing with a ditching bucket on my JCB 3CX.
The pipes were trenched 12 - 18 inches deep in the field and then pressed firmly into the silt as far as possible when crossing the water. This was done 10 years ago and the precise pipe runs locations are lost but I know them within a few feet. Obviously I want to avoid tearing up the pipe !
Neither branch has a suitable place where I could insert a tracing wire or I could easily follow them with my CAT scanner tool. (My taps are fed from underground Tee fittings on the pipe run so I cannot simply insert a wire at the tap)
Wallowing about in Google I understand that there are various device to impose an acoustic signal in the pipe that can then be located. The simplest being a solenoid valve turning water flow on / off at an adjacent tap the sensor being a fibreglass pole to put to your ear. Then there are more complex ones with amplifiers etc.
Has anyone had success with such a tool, or maybe has an unused one lying about ?
