brightspark
- yarm stockton on tees
nothing wrong it IS a suction gun nowhere near as powerfull as a pressure fed pot like thisSo what am I doing wrong here? Here's two videos
6mm: https://streamable.com/irrt0l
4mm: https://streamable.com/5ov6ya
4mm highly restrictive to media flow
What chart are you consulting ?But why is the 4mm so restrictive? 4mm is bigger than what is recommended for the CFM I have
Let's qualify some things:
Looks like decent progress in both the clips. I'd be more than happy with thatSo what am I doing wrong here? Here's two videos
its copper slag expendable . you can only use it twice otherwise your just hurtling dust and cloggs easily. sieve on the second go as wellI've never heard of that composition, but it looks allot like "Black Beauty" a brand name of coal ash (bottom ash not fly ash).
Popular over here....with some people, just not me.
It's definitely Olivine but looks quite like J-Blast as it's black. It doesn't have a mesh-size printed on the bag but gives the size-range of the particles. How does this translate to mesh-size?
makes you sprint a bit
You can buy the stuff they use for the windows in boxed toys off a 1M wide roll at wholesale plastics stockists. 2M would last a lifetime of hood windows.Well that's me finished with the blaster for now. It's packed away, place clean again after 2 days of sweeping and the item is painted.
I got on quite well with less blockages and sufficient air-power but I flt this grit was starting to go 'blunt' after only 2nd (or 3rd?) time around. On top of that the visor was opaque and I couldn't see what I was doing. I hadn't got every speck of rust off the worst areas but you have to draw a line somewhere and I decided to get some paint on the **** thing.
I will be using the blaster again, to clean some much lighter corrosion for the engine-bay of my Jag. So... I'll need more media and a new visor-pane.
The one in this hood is 225 x 177 x 1.4mm apparently and you can get them in Germany for 4.64 Euros but was hoping somewhere in UK would sell them. It's also curved so if I put flat glass or perspex in it won't fit right
new screen required for this type of hood
didn't get all the rust off
but the paint is on
and can focus on the wood now
as for the screen you can get thinish cellular clear sheet cut to size and just stick it over the visor with duct tape and rip it off when its doneIt looks like your abrasive was too coarse, and could not get down into the "nooks & crannies".Well that's me finished with the blaster for now. It's packed away, place clean again after 2 days of sweeping and the item is painted.
but the paint is on
I'm not buying any air-fed mask for blasting. I just want a new bit perspex ffs.It looks like your abrasive was too coarse, and could not get down into the "nooks & crannies".
As far as the hood goes, try a supplied air version, I have very similar to yours with a belt mounted air cooler
to blow cooled air into the hood.
Not a full blown expensive helmet, just a simple hood like you have pictured, makes a world of difference.
wot thickness and size are theyI've got the same mask.... it's adequate for occasional home use. I haven't looked for replacement lenses, but it would take much to hack them out of some sheet perspex and hold them over a gentle heat to set the curve
