ABS systems do a self test at a certain speed. For example a man fiesta tests at precisely 14mph on a gentle pull away. If your light hasn't gone out there is a problem somewherr
The only free VAGCOM is pirated/stolen/ripped/keygen'd
Well I cant see the mot guy causing your problem Unless the wheel sensor wire was caught somewhere and then again that is not his fault.gone into google overload at the mo, but could be staring down the barrel of an ABS pump pressure sensor failurecommon cause of the fault ......
I have done many thousands of tests and never once had an abs light come on during the test that wasnt cable relate. when checking the wires etc they have fell apart at the joint and that was only once!
Sorry if I have qiven you some bad adviceI have done many thousands of tests and never once had an abs light come on during the test that wasnt cable relate. when checking the wires etc they have fell apart at the joint and that was only once!
But I have just checked with two other garages and one mate has had this scenario, once, this was also the case with an audi, if the engine is off but ign is on, and the wheel spun it has shown up as this fault. This also had to be reset with diagnostic gear.
So it does look like it was the mot station.![]()
then my good mood would have evaporatedDid they charge you for a retest?
The simple fact is, do the test without the ignition on. Its a quick recipe for a flat battery and wheel speed related faults.
