MetalMonkey
- UK
White vinegar is the ticket for neutralising and cleaning leaking alkaline cells. It will fizz and just dissolve it. I'd try that before boiling water tbh.
I looked at an led for the maglite, £130. Cracking bit of kit but I’m not paying that
The next time you have battery terminal covered in corrosion, pour boiling water over it. You will be amazed.What trick with boiling water have I missed?
Apparently if you put 2 D Cell batteries in the 4D or 6 D it works like a slide hammer and hurts more. Apparently.Still got 2D, 3D and 4D, all still working fine, the 4D is next to the bed in case I need a "deterrent"
A police sergeant I knew in the 80's said the big D cell torches made an excellent alternative to a truncheon as they could put a car window through![]()
what did you use ..is there an adaptor sleeve or something i could buy..18650 are same volts as a d cell right?I nodded mine to take 2 18650 rechargeables and I would like to make a recharging cradle for the truck at some point as I just like the torch.
I've got an old dragon light, heavy with a lead acid battery and a 50w halogen sealed beam lamp but a cracking torch.For something a bit bigger, the nightsearcher trios are a good unit, had them on SAR and they do the job great
I just turned a nylon sleeve on the lathe, I’d probably just print one now though!what did you use ..is there an adaptor sleeve or something i could buy..18650 are same volts as a d cell right?
I got a drop in led unit for my 2d maglite, it’s brighter than the sun! Not horrifically expensive, I think 20ish quid at the time but I couldn’t tell you where from. Spot is phenomenal, I use it out the bedroom window to illuminate the clever sofa that haven’t noticed the sheep in the field when they take their dogs for a walk on the path. As with most leds flood isn’t great though. I nodded mine to take 2 18650 rechargeables and I would like to make a recharging cradle for the truck at some point as I just like the torch.
I used to cycle in the woods at this time of year it’s a great rush of adrenaline as even at slow speeds makes you feel like your going fasterThanks for the tip, I’ve been looking for a new torch for the car, just ordered a Nightsearcher Trio from Zoro![]()
About time I did that with my 3-cell Magalike. It's a really nice torch, but wasn't ever that good on bulb life, so bought an LED replacement when they were only just starting to show. It was pathetic, but I've never got around to replacing it with a more modern one since, just using it with the Krypton bulb and 3 cells.I nodded mine to take 2 18650 rechargeables
