I`m making a stand for my (new-to-me) 100 Kg. anvil; I have to hand, a pc. of 35mm. thick steel plate (approx. 300mm. x 450mm.) will be cutting and welding-on four legs made from 100mm. x 10mm. equal-angle and plan on using 4, 125mm. x 10mm. plate 'squares' to spread the load as 'feet'.
Not having welded to such thick-plate before; I wonder the best way to weld the underside of the 35mm. plate to the tops of the 100mm. steel-angle legs: should I pre-heat?.... prepare the legs with 'V`s'?.....or plain fillet all `round?
I have 2.5mm. and 3.2mm. 6013`s; no shortage of amps. and have a propane torch.
Thanks in advance, Debs.
