I`m making a stand for my (new-to-me) 100 Kg. anvil; I have to hand, a pc. of 35mm. thick steel plate (approx. 300mm. x 450mm.) will be cutting and welding-on four legs made from 100mm. x 10mm. equal-angle and plan on using 4, 125mm. x 10mm. plate 'squares' to spread the load as 'feet'.
Not having welded to such thick-plate before; I wonder the best way to weld the underside of the 35mm. plate to the tops of the 100mm. steel-angle legs: should I pre-heat?.... prepare the legs with 'V`s'?.....or plain fillet all `round?
I have 2.5mm. and 3.2mm. 6013`s; no shortage of amps. and have a propane torch.
Thanks in advance, Debs.
why complicate things
, does the job tho. I also extended the horn (tip) a little for bending smaller rings on.
gave permission for card to be made. Front of card was chalked out with a large heart shape (Awwwwwwwwwwe) only problem was, this lad cut out heart shape using plasma over top face of anvil, resulting with, semi heart shape gouged into top face. Not too worry tho, lad coughed up for hard facing rods to repair face, I then gave him a nail file to dress flush
this particular lad lost his balance, anvil of course fell heavily to the floor, to this day the contact indentation remains in concrete floor. The lad is now famous for being our first sending off and, expelled for a month..............
