Newlands
- Sussex, UK
I’ve got a Lucas 15acr two-wire alternator on my little tractor which is giving me a headache. It started when the charging light stayed on, so I bought a rebuild kit - new brushes, new rectifier and new regulator which I’ve fitted. Stuck it back on the tractor and I got 12.5 volts at the battery before starting, and when I started it I got 14.36v, so it’s clearly charging. But I have no charging light at all. Checked the bulb this morning and it’s ok. Checked the output at the alternator terminals and the big fat wire is giving 14.36 volts and the thinner wire is giving nothing, but it should be the same as the other one.
it’s a mystery to me - I thought that if the bulb doesn’t light then the alternator won’t start charging. I would also have thought that if there was 0 volts out of that warning light terminal then it wouldn’t be charging at 14.36v.
Any ideas from someone who is more of an expert than me (ie just about everyone) ??
