argg you made me go down into the cold garage !!
LOL
you cant have enough grinders !
just reply..
one for cutting disc.
one for grinding disc.
one for wire wheel
and one for sanding disc.
and a big 9" grinder for big stuff
so just five love.....
now how many pairs of shoes do you have ?
If you started looking at porn that only showed tools she would have a bigger problem!Recently she commented that if I looked at porn as much as I did at tools she would say I had a real big problem.
just reply..
one for wire wheel
Only problem I have found with the Lidl / Aldi grinders are the speed controlers which move all by themselves, I can set it running slowly and before long the wheel is in angry porcupine mode.Mine has a wire brush fitted most of the time with the variable speed set low enough so that if it catches the brush stops rather than jump off the work piece & attack you.
And you need a spare ........ Or twodon't forget one for blending
that's your fat fingers moving it!Only problem I have found with the Lidl / Aldi grinders are the speed controlers which move all by themselves, I can set it running slowly and before long the wheel is in angry porcupine mode.
just reply..
one for wire wheel
I've always thought that decent brand grinders like dewalt are cheap enough (£40-£60ish) and there's always one on offer somewhere, they usually have a 3 year warranty, and are much better made and nicer to use than one from lidl! I've used the cheap ones and whilst they do a job they're not a patch on a good brand one. Even if I only use it a couple of times a week it's not worth the £20 saving to me.
(this is just my opinion, other opinions are available!)
Err, you do realise that (apart from needing one for a flap and one for a poly disk) you also need one of everything for 4", the common 4.5", 5", 7" and of course the big 9". Plus a set of low profile head grinders too...
TBH after being supplied with a nasty POS Draper grinder at work which was damn horrible (don't miss it following its death!) I would agree with you.
However, I got an Aldi one because of it having variable speed for use on wire wheels and for the use it'll get it doing that there's no way to justify an expensive one and it's actually quite smooth and nice to use! So much so I want to get more - here's hoping I didn't get the odd good one...!
