Bryan Williams
- Manchester England
See , this is noughty showing me stuff like this, a little knowledge is a dangerous thing..
Just read on another post someone uses 10/40synthetic in a cheap occasional use compressor, would 10/40 mineral do OK?Looks like I might have fixed it.
Cleaned up the nrv, which was very oily and grungy.
Fired it up but the bleed plug was leaking it stopped when I unscrewed it??? It was still leaking a bit until it built up pressure then stopped.
It got up too about 116 then stopped.
Nothing was leaking,it held pressure for about 1/2hour till I decided to open the drain cock.
It will turn either way but doesn't release air,so I opened the tap on the pressure out gauge.
The oil showed 1/2inch OVER on the stick so I decided to drain it and do an oil change. It was as black as the oil in my T4.
So all in all I'm a happy bunny,felt like Doc Brown in Back to the future when he realised he had invented something that actually worked and I made a bit myself
So next thing ,buy oil, get another impeller,make a shroud too replace plastic missing one fit missing airfilter and start spraying.
One more question,it hasn't got a oil/water filter, will one from Machine mart do , the type that screws on after the gauge.
Bearing in mind I am probably only going to spray one bumper and then mess about with an airbrush?
Cheers, really appreciate your time and help with this folk.
The brass drain cock underneath?Saved £20 then
What do you mean by the bleed plug?
On mine it's brass sump plug with a brass nurled bolt through it
I grovel too no one, even under pressure.Right, you referred separately to a drain plug so i thought you had two different things. The drain cock on mine turns clockwise to close, like a tap. One think I have done is to replace the drain cock with a hose tail and fit a ball valve to the end of a length of air hose, that way it's easier to operate and there's no more grovelling on the floor.
So is it ok to just get a machine mart water filter and maybe a small filter at the gun or is oil a problem as well?Do the water filters remove any oil from the system? Just wondering whether I need an oil, water combined one. Also is it worth having a small water filter in line just before the gun.
Where do people buy their bits? Machine Mart or are there better suppliers?Depending on how various little jobs I have planned work out I'm hoping to be able to spray my van so gathering together as many decent tools /parts as possible.
Cheers, Bry.
