Tiny picture but looks like a windy gun, die grinder, ratchet, chisel and associated tooling?
That's a decent selection and will be quite versatile. How much have you seen that for and what make is it?
the largest air user in kit looks like a die grinder unless u are using it constant i cant see a problem bigger the better but where do u draw the line
unless you have a 15cfm pump on it the tank will empty in no time even 15 cfm wont run them all day even that would fade out sooner or later an air ratchet also uses quite a bit
how many bolts are u undoing 4 car wheels i only use a 14cfm comp for nearly everything even small shotblasting jobs but if needed i have 28cfm comp and 90 cfm . its not industry d i y
well at the end off the day it shuld be ok for what i need. if i empty it an 2min grinding i will just go put the kettel back on and have a nother cup of coffee or get the 240v grainder out. that will keep going a lot longer than any conpresser trust me
thanks for all your usefull info but i thank now my conpresser will do me proude
