Morning folks,
I must be honest, I have been somewhat confused by a lot of the comments so far with terms such as star and delta, VFD, transwave rotary etc. But I have done a lot of reading, so lets see if I have this right. I also have some outstanding questions.
Pillar drill:
As the plate states both 240 and 440v, I can run this using single phase. I change the arrangement from Star to Delta. I need to get a hold of a capacitor, but then I can use a normal 3 pin plug and away I go.
1) Rikrobson – you noted that for this arrangement a VFD would be good. Why? Can the motor not run as noted above without the need to buy anything but a capacitor? Is it only there to allow you to change the speed of your motor?
2) Will the motor run as designed? I have read places that I can be down rating the motor if I am not supplying with 440v…. or is that only the case for motors that do not have a 240 option?
3) How do I work out what size of capacitor I need, and where can I buy one?
Bandsaw:
My band saw is 440v only. This is where I get lost as to my options.
As I will not be using both tools at the same time, what is the best solution?
Pillar drill:
Bandsaw:
