langy
langys rodshop
- London
I use Kapci 625 daily, and find it perfectly adequate as a primer. It is 2k, and so provides a seal against anything underneath it. If you're saying it's powdery, then I would suggest that the gun is not spraying correctly, assuming you've mixed it 4:1, plus thinners. I've had this happen sometimes, or also when it's not thinned enough. HTH
Just because its 2k doesn't make it a good sealer, 2K primer can still suck in moisture, epoxy primer won't though so therefore is a good sealer.
