Migmac
- Kintyre. Scotland
Good thought...wondering if just grease or some kind of dry lube would be best.
To design the bottom bracket, I put the thing on the lift....Welding upside down is not fun...as you guys well know! the lift at least helps with getting some distance between you and the weld spatter.....
I figured out what I wanted to do with the lower bracket and will be able to unbolt it at the end of the winter if need be. it took some time. I decided to use that 1/4 plate I bought a while back. glad I did.....
It took a couple of tries to get everything squared up and tacked, but once I had it where I wanted, it went fairly well...
and the bracket mostly finished. I still have to make a few relief cuts for parts of the frame and check the bolt holes, but Im happy with that....
tired...time to sleep!
thanks for lookin
JP
I just used grease, all I have
Steady on, we usually get the tail-end of your storms about 7-10 days later, but it's FAR too early on the year for that!
