Weldinator
Astalavista baby....
Not had chance to look at the fuse box yet but iv had an idea, would i be able to hire/buy a generator with the 16amp socket ?
no earth ring on the incomer armoured . the fuse shouldnt be rated at more than 20 amp on 2.5mm cable . if it had been wired in 4.0mm cable to sockets a 30 amp would be ok
or anything else juicy in his while he's using his welder from the new 16A circuit, so his draw is only going to be around 12-14 Amps max, and most of the time a lot less. If the guy with the other garage gets into heavy welding from his 13A socket at the same time (highly unlikely!), or starts up a huge compressor, he will blow his own plug fuse at 13A - 15A.
