The_Yellow_Ardvark
I'm a citizen of Legoland travellin' incommunicado
- Going Away.
Pewter Glass bottom beer mug.
Just need to find a shilling.
Tension on the main spring No2.TenShun private
Glasd you got the spelling correct Private.
ftfy
A Ginour mask. It's all @Kram 's fault!
More amazons, holesaws, knotted wire wheel, milwauknee grinder nut. The other 14mm holesaw was refunded so I got another.. but not wanting to risk if theres bits of the old one still in the hole, ground into a two toothed one.
Teeth survived ok but its only mild.
Smaller chips, and no kerf, but it worked well.
You know it has a blue film to be removed?![]()
i also like the rest of the protective welding equipment worn - safety first
Not welding, it was just a fashion show today!
FTFY
I may have one somewhere, but it's unlikely to be a King's one.![]()
, I'll PM you later, when I'm on the desktop.Sealed End Copper rivets.
