Arclikeharrypotter
- Northampton
I was always under the impression that the first two were tensile strength, then 3rd was the positional usage of electrode, and last was to do with the composition of the flux.
This is correct.I was always under the impression that the first two were tensile strength, then 3rd was the positional usage of electrode, and last was to do with the composition of the flux.
That's were I get puzzled because a 7018 generally does not go v down but a 6011 does (but then I actually have some 7018 certified for V down).This is correct.
70(70,000 psi of tensile strength)
1= all position electrode.
?= type of flux coating. (8 would be Fe powdered low hy)
But you see 1 isn't always all positions when you include v downRemembered reading something on here some time ago. Here's the link. Will make alot of sense as to why differnt electrodes perform differently. But you'll also find the likes of super 6 don't put the same research and development in as say murex, bohler to name a few.
http://www.mig-welding.co.uk/electrode-classification.htm
I think v down is like an add on, most the time it will specify on the packet. I've often wondered the same thing as yourself. Other than open root and thin sheet I can't think of many other uses for v down.
@Hood have you etched any of your welds with the Phoenix?
Cool. Just use oven brite or similar as long as it contains sodium hydroxide it should etch. Left it on about 10 minutes.No, think the only one I have etched that was Mig was one of the first runs I did when I got the R-Tech.
The EWM is not at my workshop at the moment, I left it up where I have been fitting out the boats as I will be back there next week sometime, so can't do a test this weekend but will try and get a test done soonish as it would be interesting to see.
Now where can I get a really decent set of leads with a good quality crocodile style stinger? All the ones ive got recently have been really poor quality, I still think the BOC twist style clamp is the most heavy duty thing ive used.
I have been using Avesta Pickling paste, seems to work but maybe the oven brite would be better?Cool. Just use oven brite or similar as long as it contains sodium hydroxide it should etch. Left it on about 10 minutes.
