Ok one for the sparkys
Wanting to change consumer unit , currently have no rcd but the following circuits : shower 40 amp
2x 32 amp ring mains
1x16 amp oven
2x6amp lighting
Anyway I already have a new split load cu with 2 x rcds to fit
How should I split the load between the two rcds ? I'm thinking rcd 1 : shower /ring main 1/lighting 1
Rcd 2 :ring main 2/oven /lighting 2
Allso I want to add an outdoor double socket on radial circuit using 2.5 twin and earth and 16 amp Mcb , I'll be wanting to plug in a 110v 3kva transformer this sometimes trips the 32amp type B breaker (inrush current ? ) so can I fit a different type of breaker ? Or should I make the circuit a ring with 32 amp breaker ?
Cheers mike
1x16 amp oven
2x6amp lighting
Cheers mike
. I doubt you can buy the metal casing bare tho and swop over the mcbs / rcds .
just spur it off the 32 amp ring and wire in 2.5mm. any earth faults it will knock the rcd off anyhow . keep it simple
