I thought the timing side crankshaft bush was the A65's big weak point, also the aluminium oil pump that warped and for some of the post 1966 bikes and the drive side crankshaft bearing change from a ball to a roller allowed side movement of the crank and wore out the thrust washers were also not great. The good news was that Devimead developed solutions, now available from SRM http://www.srmclassicbikes.com/devimead.I have a 1958 A10 650 meself. Its all been repainted, i just have to buy the stainless fasteners to bolt it all back together.
The reputation for knocking out big ends probably comes from people not changing the oil often enough, causing the main bearing bush to wear, causing low oil pressure at the big ends.
I do not disagree, though there were some great engineers employed in the motorcycle industry, just not putting the profits back into design, development and replacing worn out machine tools that resulted in bikes like the A65.I think the problem was down to continuously up-rating an old design to the point where is couldn't handle the power. The original A7 was designed in 1938 for release in in 1939. The same happened with the Norton twin, it started out as a 500 and ended up as an 850 without too much thought being given to the design. Having said that, if you put one together properly and treat them with respect and are regular with oil changes, they do keep going.
yer dead on i had an a65 with a devimead 750 kit it went ok till the timing side bush wroe out and big end nipped up ,however i got an ex sidecar racing motor that had thrown a rod ,i got the small bit of damage to the lh crankcase gas welded at the tech college at the time,crank was highly modded with an ina needlie needle roller bearing roller bearing and an end feed quill, internals were all drilled and polished and there was a close ratio box after weeks of trying to cure a misfire it was traced to a worn ignition switch
definitely one i wished i had kept it went well , i think you could get them out to 820 with an A10 crank and a few have been fitted with 270 deg cranks (rotated and welded together i believe) carrillo rods a good mod too,SRM engineering do all the mods that DEVIMEAD formerly used and it makes them a very reliable strong sorted motor
Well got the head off yesterday, took it to me mate, put it on his flat plate, nowt wrong, I recon someone took the head off and had it soda blasted then put it back together without torqing it up properly.
All looks brand new, gasket looks new, head to clean for a 45 year old bike.
Put it back together at the weekend with me borrowed tools.
Probably fit electronic ignition over the winter.
In my long gone biking days I always wanted a BSA but seemed to have ended up with owning nothing but Triumphs. Sorry for the derail but a few snaps of a Beeza one of the lads that worked here restored.
Very nice!!
Is that a Spitfire thought Rocket Goldies were pre unit?Cannot resist uploading this. Anyone know the dealers ?
