hi guys I'm fairly new to this but I'm in the market for a mig. Mainly to be used for automotive type stuf exhausts sills etc. I have done some welding before with a unit that the metalsmith uses at my work, it was a merkle unit I sir of what model but fairly large trolley type .
I used this to stitch weld my rally car shell and mess about making a few bits and bobs but not enough to know the ins and outs of what makes a good welder.
So I have found these 2 on the old Bay. Read a little about them and decided I'd like some thing that will go up to 200amp so I have the ability to do a bit of fabrication should I decide to.
The smaller inverter type is attractive as I will be able to use it in the van out on jobs and keep the gas bottle in there with a large hose.
What I don't want to do is buy something that is difficult to use for a fairly beginner as I used a small sealey thing and it was *****.
Mod Edit: Just a heads up as you are new, if you see ***** in your advert you are using language against the forum rules.
Option 1 https://www.ebay.co.uk/itm/222287213414
Option 2
https://www.ebay.co.uk/itm/132152829290
Cheers
Option 2
Cheers
And what do you anticipate welding , e.g material/thickness etc?
